Hi, is it ok in ignition to generate my own ssl/tls certificate to use it in my gateway or i should have a CA to generate it
Ignition itself won't care. But if the certificate isn't signed by a recognized CA, then browsers will object to connect with your Ignition gateway. (Unless you use your own CA, and make all of the browsers that you use trust it.)
If you wish to avoid paying for a certificate, look into the Let's Encrypt service.
is it possible to use and test with 2 hrs trial mode?
Sure, if you mean "can I test certificates" in two-hour trial mode. Certificate functionality isn't limited by an expired trial, anyways.
