In Ignition version (8.1.38) sepasoft (3.81.9)Production and OEE Module Imported .In perspective Component Getting error for not found.
Have you looked for messages in your designer log?
(You might also want to contact Sepasoft support.)
Looks like you've imported a project that uses Sepasoft components, but have not installed the Sepasoft module that supplies the components. Go look at your gateway's web interface, Config => System => Modules.
No, I'm using new project
The problem isn't obvious to me. You should contact Sepasoft.
it's working vision module.
Can you print this to the console: system.mes.isProductionStarted()
If that is a no, please check you allocated a database for mes:
https://docs.sepasoft.com/articles/#!mes-module-tutorials/setting-up/a/h2__836825541
