Ignition Server and Edge Gateway Versions
Is there any problems with having the central ignition gateway (where the Mqtt Distributor module is at) on a different version than the edge gateways using the transmission module?
For example, if the gateway is on 8.1.31 and the edge gateways are at 8.1.23.
Probably should ask this on Cirrus Link's own forum, hmm?
Cirrus Link's answer:
