Hello,
Is there a way to find what's causing the High CPU and Memory Usage?
I only have 1 designer and 1 Perspective instance open, and the CPU and Memory just went up.
I'm using Ignition 8.1.18 and I attached a photo for reference
Can you check in Gateway --> Status --> Diagnostics --> Execution
Good lord, that is pathological! And with only one hour of uptime. That suggests your application contains many infinite recursion problems and/or circular binding problems. But that is just a guess. Is there anything odd showing in your gateway logs?
Consider taking a thread dump. And possibly a heap dump or flight recording. Some techniques to pursue:
https://forum.inductiveautomation.com/search?q=java%20flight%20recorder%20order%3Alatest
Also consider opening a support ticket and having IA look over your shoulder.
