I have ignition 8.1.5 running on ubuntu 20.04. The system time and time zone are set correctly in ubuntu, however Ignition has the incorrect time. Any way to fix this?
How are you running Ignition? What user is Ignition running as?
If all else fails, you can override Java’s timezone detection from the system via an ignition.conf parameter:
https://wrapper.tanukisoftware.com/doc/english/prop-timezone.html
