Hey guys,
Sometime last night our Primary ignition server had some type of error that caused the system to stop working. CPU usage was pegged, OPC communications seemed to have stopped and trending was not working at all. The gateway was still up however, so all of the clients were connected to the Master and the backup never took over because technically the master was still up but hours of data was lost. I restarted the Ignition service this morning when I got in and everything seemed to be ok. I looked through the logs and there is 50 MB of the following error:
INFO | jvm 1 | 2015/05/13 07:33:38 | ERROR [PublishRequestPump ] [07:33:38,545]: Received failure notification for request '[PublishRequest requestHandle=43875664]'.
INFO | jvm 1 | 2015/05/13 07:33:38 | StatusCode[Severity=Bad, Subcode=Bad_SessionIdInvalid]: ServiceFault: StatusCode[Severity=Bad, Subcode=Bad_SessionIdInvalid]
INFO | jvm 1 | 2015/05/13 07:33:38 | at com.inductiveautomation.xopc.client.stack.TCPClientChannel.validateResponseType(TCPClientChannel.java:824)
INFO | jvm 1 | 2015/05/13 07:33:38 | at com.inductiveautomation.xopc.client.stack.TCPClientChannel.receiveMessage(TCPClientChannel.java:785)
INFO | jvm 1 | 2015/05/13 07:33:38 | at com.inductiveautomation.xopc.common.stack.UAChannel$1DeliverMessage.deliver(UAChannel.java:967)
INFO | jvm 1 | 2015/05/13 07:33:38 | at com.inductiveautomation.xopc.common.stack.UAChannel$DeliverToDelegate.run(UAChannel.java:1599)
INFO | jvm 1 | 2015/05/13 07:33:38 | at com.inductiveautomation.xopc.client.stack.SerialExecutionQueue$RunnableExecutor.execute(SerialExecutionQueue.java:100)
INFO | jvm 1 | 2015/05/13 07:33:38 | at com.inductiveautomation.xopc.client.stack.SerialExecutionQueue$RunnableExecutor.execute(SerialExecutionQueue.java:97)
INFO | jvm 1 | 2015/05/13 07:33:38 | at com.inductiveautomation.xopc.client.stack.SerialExecutionQueue$PollAndExecute.run(SerialExecutionQueue.java:75)
INFO | jvm 1 | 2015/05/13 07:33:38 | at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
INFO | jvm 1 | 2015/05/13 07:33:38 | at java.util.concurrent.FutureTask.run(Unknown Source)
INFO | jvm 1 | 2015/05/13 07:33:38 | at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(Unknown Source)
INFO | jvm 1 | 2015/05/13 07:33:38 | at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
INFO | jvm 1 | 2015/05/13 07:33:38 | at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
INFO | jvm 1 | 2015/05/13 07:33:38 | at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
INFO | jvm 1 | 2015/05/13 07:33:38 | at java.lang.Thread.run(Unknown Source)
I don’t know if this is the cause or if this is an effect. I can’t go back to when it happened because that 50 MB of logs spans about 3 minutes, all this error. Can someone tell me what this error is pointing to? Could it be a memory issue (memory was pretty close to being maxed out)?
