Ignition Service will not start on Windows Datacenter 2022 with Code 7024 Incorrect Function
I am currently running into this issue after the server has restarted. I have not managed to get the Ignition service back up and running. I have attached the wrapper for help in diagnosing this issue as I have found it in the forum. No one has posted a resolution.
Wrapper.txt (11.4 KB)
I would contact support
Failed to bind 0.0.0.0:8043 and 0.0.0.0:8088 due to addresses already in use. Use netstat to determine what other software is blocking Ignition's use of those ports.
As it turns out. I had a web service redirect on the server that was conflicting with Ignition causing it to fault out.
