Ignition - Setting up Azure SSO, HTTP ERROR 400 Bad Request
Hi Team,
I am trying to set up SSO for Ignition and Azure. I followed the instructions here at SAML Example - Ignition User Manual 8.0 - Ignition Documentation, and imported the SAML Metadata file. When I did a test login on Ignition I don't see any error, however when I tried testing the Single Sign On application on Azure, it comes out with the following error.
URI: /data/federate/callback/saml/bridge
STATUS: 400
MESSAGE: Bad Request
Are you able to assist me with this issue? Not sure if I am missing any steps in configuring the Identity Providers / Enterprise Applications Single Sign On (Azure)
Any chance you got this working correctly with Azure?
