Ignition simple report (using Tag history )
report.pdf (63.1 KB)
Hi ,
there are two issues in my ignition report:
1-I created simple report in ignition from tag history. I assigned the tag but in report viewer in the first row the data is incorrect, and the rest are correct.
2- I shows some empty row and no data on that. first row I have data and second row with different timestamp I do not have any data.
Would you please advise me.
Thanks,
Mally
Hi Mally,
The Tag Historian Query is returning the dataset based on the query configuration in the Report and will not display tag history as stored in the database unless specified in the Tag Historian Query data source. I suggest opening a ticket up with Support so an Engineer can take a look at the configuration.
https://support.inductiveautomation.com/hc/en-us
