Ignition 8.1, MSSQL.
Hi.
I am using Ignition to monitor the operating status and collect downtime codes from several CNC machines. These integer values are logged by the ignition tag historian on value change. The goal is to calculate OEE and determine the most frequent causes of downtime.
For the operating status, I have written a script that loads a snapshot of data from the historian. This is passed through a case select (multiple ifs) which increment a timer for each value of interest. The end result is a summary dataset with the total number of seconds spent in each state (within the time window). This is converted to % in another function. This works OK when there are only a handful of values to scan for. Now I must repeat this for the downtime codes. There are >10 codes and these are also stored in a SQL table. Is there a less clunky solution using inbuilt functions or the SQL server itself?
Some of my code for the CNC machine operating status analysis is below.
def returnStateSeconds(sqlData):
# Iterate through the dataset and increment timers for each state.
# Declare variables
cutting = float(0)
idle = float(0)
error = float(0)
no_data = float(0)
# convert to pydataset
pyData = system.dataset.toPyDataSet(sqlData)
for i in range(len(pyData) - 1):
if pyData[i][1] == 0:
no_data += system.date.secondsBetween(pyData[i][0], pyData[i+1][0])
elif pyData[i][1] == 1:
idle += system.date.secondsBetween(pyData[i][0], pyData[i+1][0])
# Note. State codes 2 (In process) and 3 (OP30) are grouped together into "Cutting".
elif pyData[i][1] == 2 or pyData[i][1] == 3:
cutting += system.date.secondsBetween(pyData[i][0], pyData[i+1][0])
elif pyData[i][1] == 4:
error += system.date.secondsBetween(pyData[i][0], pyData[i+1][0])
utilData = [] # Create an empty list
headers = ["state", "seconds"] # Set the dataset headers
states = ["Cutting", "Idle", "Error", "No data"] # List of states
seconds = [cutting, idle, error, no_data] # List of data
for j in range(len(states)): # Add the rows to the list
utilData.append([states[j],seconds[j]])
return system.dataset.toDataSet(headers,utilData) # Return the data as a normal dataset
Similar questions have been raised in these posts without a full solution.
How to get the total time of an active tag for every hour? - Ignition - Inductive Automation Forum
Historical tags - Ignition - Inductive Automation Forum
Any help would be great.
Thanks!
