We have ignition tags that are showing good quality despite their corresponding topserver tags showing bad quality. We confirmed this through quick client. We have also confirmed that the ignition tags have not updated since the topserver tags went bad. What could be causing this?
What version of Ignition are you using and what version of topserver?
Usually this is a bug in the server of some kind. With OPC, the server is responsible for sending changes to the client.
We found the likely issue. It is likely an issue with our tag structure having too many devices on one channel. When we flattened out our structure somewhat the issue was resolved. Thanks for your help!
