Hi guys, so i’d like to know if it is possible to be able to compare a tag value on ignition with an excel sheet to get another value. the part number coming from the PLC needs to be compared to a excel sheet and be able to read the number it corresponds to. not sure if its possible to look into an excel sheet by itself figured either there is a way or some kind of work around. Thank You as always!!!
There are a couple of modules in the online store that will do what you want.
marketplace.inductiveautomation. … oduleId=73
marketplace.inductiveautomation. … oduleId=89
The Kymera module’s description only talks about exporting to excel, but they both expose Apache’s POI library. So either will work.
Thank you, I installed the PA office and gonna mess around with it hopefully i figure it out.
you could easily do this with a csv file also, without buying anything. not sure if you require a xls/xlsx file, just throwing it out there.
diat150, could you explain a bit more? are you saying I can do the comparison the way I want it with a csv file?
first, install this in your script modules. mine was named csv
# Hello, this script is written in Python - http://www.python.org
r'''Simple CSV file reader, version 0.0.2 (2002-11-06) , which can handle unlimited-sized CSV files.
This parser can read:
- CSV (Comma-separated value) files (,)
- SCSV (Semi-colon-separated value) files (;)
- TSV (Tab-separated value) files (tabulation)
This parser:
- supports lines with mixed quoted and unquoted strings.
- supports cells which contain newlines (quoted strings spanning
on several lines).
- can optionnaly ignore comments.
- can optionnaly ignore empty lines.
- can optionnaly strip left and right spaces in cells.
- can efficiently iterate over very large CSV files without eating
all the memory.
- can handle very badly-formatted CSV files.
- does not use regular expressions (which makes it faster
and "Maximum recursion limit exceeded"-error-proof.)
This class is very easy to use : open the file, and use nextrow()
to get each CSV row.
Usage example:
import SCSV # import the SCSV module
mydata = SCSV.SCSV() # Create a SCSV parser
mydata.opencsv('cat1.csv') # Open a csv file for reading.
currentrow = mydata.nextrow() # Read a row
while currentrow: # While there are remaining row, read and print them.
print currentrow
Versions:
2002-06-27 : First version.
2002-06-28 : - added next() method for iteration.
- removed extraneous \n at the end of each row.
- added support for TSV (tab-separated) and SCSV
(SemiColon-separated) files.
- added optional close() method.
- fixed problem with a special case (spaces between
quoted string marker and columns delimiter)
- added option to ignore comments (line starting with #)
- added option to ignore empty lines.
- added option to strip spaces in each cell.
- added getallrows() method to return the whole CSV file
at once [USES MORE MEMORY]
- added methods to return current line and row number
in CSV file (usefull for error reporting).
2002-07-01 : - changed _startswith() and _endswith() to the native
methods string.startswith() and .endswith()
- added columnseparator()
0.0.2 (2002-11-06):
- corrected an ugly stupid bug (yuk!).
- added version number for easier tracking.
FIXME : Transform this class into an iterator for a more Pythonic programming
style.
FIXME : add support for named columns
FIXME : add support for CSV/TSV/SCSV writing
License:
This program is public domain. You can freely reuse it.
If you make use of this program, I would appreciate to be informed.
class SCSVError(Exception): pass
class SCSV:
'''Simple CSV file handler. '''
# States for the parser (used in _parsecsvline())
_NORMAL = 0
_IN_STRING = 1
def __init__(self, verbose = None):
self._COLUMN_SEPARATOR = ',' # Default columns separator : comma (,)
self._QUOTING_DELIMITER = '"' # Default string delimiter : doublequote (")
self._HAS_COMMENTS = None # Default do not ignore line who's first character is #
self._IGNORE_EMPTY_LINES = 1 # Default do not ignore empty lines.
self._STRIP_CELLSPACES = 1 # Default Do not strip left and rights spaces in each cell.
self._currentLine = -1 # Line counter in the CSV file.
self._currentRow = -1 # Row counter in the CSV file.
self.file = None # File handle
self.lineiterator = None # Iterator over the lines of the file.
def columnseparator(self):
''' Return the current columns separator. '''
return self._COLUMN_SEPARATOR
def opencsv(self, filename):
''' Open a CSV file (Comma-separated value) for reading. '''
try: # Try to open the file
file = open(filename,'r')
except:
raise SCSVError, 'Could not open file %s for reading.' % filename
self.lineiterator = file.readlines()
self._currentLine = 0
self._currentRow = 0
def opentsv(self, filename):
''' Open a TSV file (Tab-separated value) for reading. '''
self._COLUMN_SEPARATOR = '\t'
except:
def openscsv(self, filename):
''' Open a SCSV file (Semi-Colon-separated value) for reading. '''
self._COLUMN_SEPARATOR = ';'
except:
def close(self):
''' Explicitly close the file (if you need the file to be freed and you don't
want the garbage collector to close it for you.
In normal operation, you do not need to call this method. The garbage collector
will close the file for you.
try:
self.file.close()
except:
pass
self.file = None
def currentLineNumber(self):
''' Returns the current line number in the CSV file. '''
return self._currentLine
def currentRowNumber(self):
''' Returns the current row number in the CSV file. '''
return self._currentRow
def hasComments(self, v):
''' Instruct the SCSV parser to ignore lines who's first character is #.
Input : v true -> ignore lines who's first character is #
false -> consider all lines CSV data.
self._HAS_COMMENTS = v
def ignoreEmptyLines(self, v):
''' Instruct the SCSV parser to ignore empty lines.
Input : v true -> the SCSV parser will ignore empty lines
false -> empty lines will be considered empty data rows.
self._IGNORE_EMPTY_LINES = v
def stripCellSpaces(self, v):
''' Instruct the SCSV parser to strip left and right spaces in each cell.
Input : v true -> the SCSV parser will strip left and right spaces.
false -> cell will be left as-is with their spaces.
self._STRIP_CELLSPACES = v
def nextrow(self):
''' Return next row from the CSV file, reading as many lines as needed from
the CSV file.
Output : a tuple containing the cells of the row.
or None if there are no more rows.
if self.lineiterator == None:
raise SCSVError, 'Cannot give next row: No file opened for reading. Use opencsv()/opentsv()/openscsv() method before calling nextrow().'
# We read a line from the CSV file as long as the _parsecsvline() method tells us
# the row is incomplete. Thus we can handle quoted string which contain newlines.
try:
line = self.lineiterator[self._currentLine] # Read a single line from the file.
self._currentLine += 1
except: # StopIteration exception means we are at the end of the file.
return None # There are not more lines in the CSV file.
else:
currentrow = line
( columns, requiresmore, ignore ) = self._parsecsvline(currentrow)
if ignore: currentrow = ''
while requiresmore: # Loop if we need more lines from the CSV file to complete the current row.
try:
line = self.lineiterator[self._currentLine] # Read a line from the file.
except:
self._currentRow += 1
return columns # There are not more lines in the CSV file, return the current row as it is.
else:
currentrow += line # Append line read from the CSV file to our current row.
( columns, requiresmore, ignore ) = self._parsecsvline(currentrow) # Decode CSV and check if the row is complete.
return columns
def getallrows(self):
''' Return all rows of the CSV file at once.
Output : a list containing rows. Each row is a list of columns.
allrows = []
currentrow = self.nextrow() # Read a row
allrows.append(currentrow)
return allrows
def _parsecsvline(self, line):
'''Parse a single CSV line. Can handle badly-terminated quoted strings.
Input : line = a line from a CSV file.
Output : ( columns, isIncomplete, ignore )
columns = a list containing values of each cell, with quoted strings unquoted.
If a quoted string is not properly terminated, isComplete will be true.
(This can append when a cell contains newline character).
ignore tells the caller is this row is to be ignore or not.
Line to ignore can be comments and/or empty lines (see
hasComments() and ignoreEmptyLines().
rawsplit = line.split(self._COLUMN_SEPARATOR)
cleansplit = []
i = 0
if self._HAS_COMMENTS and line.startswith('#'): return (None, 1, 1)
if self._IGNORE_EMPTY_LINES and len(line.strip()) == 0: return (None, 1, 1)
state = self._NORMAL
while i < len(rawsplit):
cell = rawsplit[i]
if state == self._NORMAL: # We are not in a quoted string: add a new cell.
if cell.lstrip().startswith(self._QUOTING_DELIMITER):
state = self._IN_STRING # We enter a quoted string
if cell.rstrip().endswith(self._QUOTING_DELIMITER):
cleansplit.append( cell.strip()[1:-1].replace(self._QUOTING_DELIMITER * 2 ,self._QUOTING_DELIMITER))
else:
cleansplit.append(cell.lstrip()[1:]) # remove the quotes
else:
cleansplit.append(cell) # We are not in a quoted string, just append the cell.
else: # We are in a quoted string: append the content of the current cell to the previous cell.
if cell.rstrip().endswith(self._QUOTING_DELIMITER): # This is the end of the quoted string
state = self._NORMAL # We exit a quoted string
cleansplit[-1] = (cleansplit[-1] + self._COLUMN_SEPARATOR + cell.rstrip()[:-1]).replace(self._QUOTING_DELIMITER * 2,self._QUOTING_DELIMITER) # remove the ending quote, and append the content of the current cell to the previous cell.
else:
cleansplit[-1] += self._COLUMN_SEPARATOR + cell
i += 1
if len(cleansplit[-1]) > 0:
if cleansplit[-1][-1] in ('\n','\r'): cleansplit[-1] = cleansplit[-1][:-1] # Strip the last \n from the line.
if self._STRIP_CELLSPACES: # If caller asked to strip left and rights spaces in each cell.
return ( [i.strip() for i in cleansplit], state, None)
else:
return (cleansplit, state, None)
if __name__ == "__main__":
print __doc__
Not sure where I found that, it was either here or in the training class.
mext, you would need to figure out how you are going to trigger the script to read the file, but for this example, it would be in a action performed event handler on a button. This script assumes you have a header row
from app.csv import SCSV
path = 'c:\\mytags.csv'
data = SCSV()
data.opencsv(path)
currentrow = data.nextrow()
while currentrow:
tagPath = currentrow[0]
tagValue = currentrow[1]
if 1 == 1:
print tagPath
print tagValue
Im not sure exactly what you need to do, so I just put 1 == 1 for the if statement. if you need to do some kind of comparison, that is where you would start.
I also had alot of issues with getting the indents right when pasting this code and I see it is still messed up. everything under while current row should be on the same indent except for the 2 print statements.
I never got to thank you for this, I ended up not needing it (went with a table in DB) but still appreciate the help.
