I have been trying to use the system.opc.readValue() function
I have successfully read a tag but when I try to reference the “quality” attribute I get
[code]AttributeError: write-only attr: quality
at org.python.core.Py.AttributeError(Py.java)
at org.python.core.PyBeanProperty._doget(PyBeanProperty.java)
at org.python.core.PyObject._doget(PyObject.java)
at org.python.core.PyInstance.__findattr__(PyInstance.java)
at org.python.core.PyObject.__getattr__(PyObject.java)
at org.python.pycode._pyx275.f$0(<TagChangeScript:ForceOnTop>:4)
at org.python.pycode._pyx275.call_function(<TagChangeScript:ForceOnTop>)
at org.python.core.PyTableCode.call(PyTableCode.java)
at org.python.core.PyCode.call(PyCode.java)
at org.python.core.Py.runCode(Py.java)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:367)
at com.inductiveautomation.ignition.common.script.TagChangeScriptManager$TagChangeScriptHandler.tagChanged(TagChangeScriptManager.java:118)
at com.inductiveautomation.ignition.client.sqltags.impl.ChangeNotifier.run(ChangeNotifier.java:37)
at com.inductiveautomation.ignition.client.sqltags.impl.db.DatasourceTagManager$BatchNotifier.run(DatasourceTagManager.java:765)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
[/code]
This is my “test” code
qv = system.opc.readValue("IgnitionOPCUA","[ControlLogixPLC]Global.Tag_To_Be_Read")
#these work
print qv.value
print qv.timestamp
#these cause the error
print qv.quality
print qv.quality.isGood()
Is there something I’m missing?
