Ignition V7.9.16 - Garbage Collector issue
I am running a 2 client Vision based system on V7.9.16
I am atempting to get the server to have more memory available, and to change the garbage collectors to G1C1.
I a have made the required changes to ignition.conf, but it does not seem to load the changes, even if I restart the gateway?
What am I doing wrong?
Did you leave in the old GC settings? Show all of the “additional” settings from your ignition.conf.
(And yes, once correct, a restart is required.)
Thanks for the quick reply
I was having this add-in done remotely (oldschool over the telephone step by step)
My mistake was assuming that the “hands” was following instructions.
He was editing the wrong ignition.conf file (wrong directory).
Once I realized this, and got him to fix the actual right file, everything responded as expected.
Sorry for the trouble. Real id10t misktake from my side.
Nah. You do this work enough, you get this sort of thing. (:
