Ignition v8.3 Image Management Export Broken File Structure
Version: 8.3.1
I have a nested file structure in image management with one or two level nested folders containing images. The export function seems to be flattening the file structuring when exporting, making all folders and files in the target folder instead of maintaining the nested structure.
Tested with v8.1.48 and this function works fine.
Out of curiosity, what OS are you running the designer (and the gateway) from?
Either way it's obviously a bug, but it may be part of the root cause.
Windows 10
Same issue on my windows 10 version 1809.
