Ignition service is running but gateway is not starting. İgnition version 8.1.1 and sharing wrapper.log
STATUS | wrapperm | 2021/01/03 13:28:09 | Starting the Ignition service...
STATUS | wrapper | 2021/01/03 13:28:12 | --> Wrapper Started as Service
STATUS | wrapper | 2021/01/03 13:28:12 | Java Service Wrapper Standard Edition 64-bit 3.5.42
STATUS | wrapper | 2021/01/03 13:28:12 | Copyright (C) 1999-2020 Tanuki Software, Ltd. All Rights Reserved.
STATUS | wrapper | 2021/01/03 13:28:12 | http://wrapper.tanukisoftware.com
STATUS | wrapper | 2021/01/03 13:28:12 | Licensed to Inductive Automation for Inductive Automation
STATUS | wrapper | 2021/01/03 13:28:13 | Launching a JVM...
INFO | jvm 1 | 2021/01/03 13:28:13 | WrapperManager: Initializing...
INFO | jvm 1 | 2021/01/03 13:28:14 | 13:28:14,150 |-INFO in ch.qos.logback.classic.LoggerContext[default] - Found resource [data\\logback.xml] at [file:/C:/Program%20Files/Inductive%20Automation/Ignition/data/logback.xml]
INFO | jvm 1 | 2021/01/03 13:28:14 | 13:28:14,231 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.core.ConsoleAppender]
INFO | jvm 1 | 2021/01/03 13:28:14 | 13:28:14,233 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [SysoutAppender]
INFO | jvm 1 | 2021/01/03 13:28:14 | 13:28:14,238 |-INFO in ch.qos.logback.core.joran.action.NestedComplexPropertyIA - Assuming default type [ch.qos.logback.classic.encoder.PatternLayoutEncoder] for [encoder] property
INFO | jvm 1 | 2021/01/03 13:28:14 | 13:28:14,256 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [com.inductiveautomation.logging.SQLiteAppender]
INFO | jvm 1 | 2021/01/03 13:28:14 | 13:28:14,263 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [DB]
INFO | jvm 1 | 2021/01/03 13:28:14 | 13:28:14,786 |-INFO in ch.qos.logback.core.db.DataSourceConnectionSource@42481d1b - Driver name=SQLite JDBC
INFO | jvm 1 | 2021/01/03 13:28:14 | 13:28:14,786 |-INFO in ch.qos.logback.core.db.DataSourceConnectionSource@42481d1b - Driver version=3.23.1
INFO | jvm 1 | 2021/01/03 13:28:14 | 13:28:14,786 |-INFO in ch.qos.logback.core.db.DataSourceConnectionSource@42481d1b - supportsGetGeneratedKeys=true
INFO | jvm 1 | 2021/01/03 13:28:15 | 13:28:15,430 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.classic.AsyncAppender]
INFO | jvm 1 | 2021/01/03 13:28:15 | 13:28:15,435 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [SysoutAsync]
INFO | jvm 1 | 2021/01/03 13:28:15 | 13:28:15,436 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [SysoutAppender] to ch.qos.logback.classic.AsyncAppender[SysoutAsync]
INFO | jvm 1 | 2021/01/03 13:28:15 | 13:28:15,436 |-INFO in ch.qos.logback.classic.AsyncAppender[SysoutAsync] - Attaching appender named [SysoutAppender] to AsyncAppender.
INFO | jvm 1 | 2021/01/03 13:28:15 | 13:28:15,439 |-INFO in ch.qos.logback.classic.AsyncAppender[SysoutAsync] - Setting discardingThreshold to 51
INFO | jvm 1 | 2021/01/03 13:28:15 | 13:28:15,443 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.classic.AsyncAppender]
INFO | jvm 1 | 2021/01/03 13:28:15 | 13:28:15,447 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [DBAsync]
INFO | jvm 1 | 2021/01/03 13:28:15 | 13:28:15,447 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [DB] to ch.qos.logback.classic.AsyncAppender[DBAsync]
INFO | jvm 1 | 2021/01/03 13:28:15 | 13:28:15,447 |-INFO in ch.qos.logback.classic.AsyncAppender[DBAsync] - Attaching appender named [DB] to AsyncAppender.
INFO | jvm 1 | 2021/01/03 13:28:15 | 13:28:15,447 |-INFO in ch.qos.logback.classic.AsyncAppender[DBAsync] - Setting discardingThreshold to 51
INFO | jvm 1 | 2021/01/03 13:28:15 | 13:28:15,447 |-INFO in ch.qos.logback.classic.joran.action.RootLoggerAction - Setting level of ROOT logger to INFO
INFO | jvm 1 | 2021/01/03 13:28:15 | 13:28:15,447 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [SysoutAsync] to Logger[ROOT]
INFO | jvm 1 | 2021/01/03 13:28:15 | 13:28:15,448 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [DBAsync] to Logger[ROOT]
INFO | jvm 1 | 2021/01/03 13:28:15 | 13:28:15,448 |-INFO in ch.qos.logback.classic.joran.action.ConfigurationAction - End of configuration.
INFO | jvm 1 | 2021/01/03 13:28:15 | 13:28:15,448 |-INFO in ch.qos.logback.classic.joran.JoranConfigurator@367e5204 - Registering current configuration as safe fallback point
INFO | jvm 1 | 2021/01/03 13:28:15 | 13:28:15,490 |-INFO in ch.qos.logback.classic.jul.LevelChangePropagator@698c4a36 - Propagating INFO level on Logger[ROOT] onto the JUL framework
INFO | jvm 1 | 2021/01/03 13:28:15 | W [WebResourceManagerImpl ] [10:28:15]: Unable to read "gateway.metroKeystoreAlias" gateway.xml property. Assuming metro keystore alias is: metro-key
INFO | jvm 1 | 2021/01/03 13:28:15 | I [o.e.j.u.log ] [10:28:15]: Logging initialized @2250ms to org.eclipse.jetty.util.log.Slf4jLog
INFO | jvm 1 | 2021/01/03 13:28:15 | I [g.WebServerManager ] [10:28:15]: Starting setup
INFO | jvm 1 | 2021/01/03 13:28:15 | I [g.WebServerManager ] [10:28:15]: gateway.forceSecureRedirect property is not set. Defaulting to false
INFO | jvm 1 | 2021/01/03 13:28:15 | I [g.WebServerManager ] [10:28:15]: gateway.includedCipherSuites property is not set. Defaulting to []
INFO | jvm 1 | 2021/01/03 13:28:15 | I [g.WebServerManager ] [10:28:15]: gateway.excludedCipherSuites property is not set. Defaulting to []
INFO | jvm 1 | 2021/01/03 13:28:15 | I [g.WebServerManager ] [10:28:15]: gateway.publicAddress.autoDetect property is not set. Defaulting to true
INFO | jvm 1 | 2021/01/03 13:28:15 | I [g.WebServerManager ] [10:28:15]: gateway.publicAddress.address property is not set. Defaulting to
INFO | jvm 1 | 2021/01/03 13:28:15 | I [g.WebServerManager ] [10:28:15]: gateway.publicAddress.httpPort property is not set. Defaulting to
INFO | jvm 1 | 2021/01/03 13:28:15 | I [g.WebServerManager ] [10:28:15]: gateway.publicAddress.httpsPort property is not set. Defaulting to
INFO | jvm 1 | 2021/01/03 13:28:15 | I [g.WebServerManager ] [10:28:15]: Setup complete
INFO | jvm 1 | 2021/01/03 13:28:15 | I [Commissioning ] [10:28:15]: Commissioning State updated from commıssıonıng to needs_commıssıonıng
INFO | jvm 1 | 2021/01/03 13:28:16 | I [g.WebServerManager ] [10:28:16]: Starting up
INFO | jvm 1 | 2021/01/03 13:28:16 | I [C.SecureRandomProvider ] [10:28:16]: Secure random seed generated in 0ms
INFO | jvm 1 | 2021/01/03 13:28:16 | I [o.e.j.s.Server ] [10:28:16]: jetty-9.4.24.v20191120; built: 2019-11-20T21:37:49.771Z; git: 363d5f2df3a8a28de40604320230664b9c793c16; jvm 11.0.7+10-LTS
INFO | jvm 1 | 2021/01/03 13:28:16 | I [o.e.j.s.session ] [10:28:16]: DefaultSessionIdManager workerName=node0
INFO | jvm 1 | 2021/01/03 13:28:16 | I [o.e.j.s.session ] [10:28:16]: No SessionScavenger set, using defaults
INFO | jvm 1 | 2021/01/03 13:28:16 | I [o.e.j.s.session ] [10:28:16]: node0 Scavenging every 600000ms
INFO | jvm 1 | 2021/01/03 13:28:16 | I [o.e.j.s.h.ContextHandler ] [10:28:16]: Started o.e.j.w.WebAppContext@4c85a985{Commissioning,/,file:///C:/Program%20Files/Inductive%20Automation/Ignition/webserver/webapps/commissioning/,AVAILABLE}
STATUS | wrapperm | 2021/01/03 13:28:17 | Ignition service started.
INFO | jvm 1 | 2021/01/03 13:28:16 | I [o.e.j.s.AbstractConnector ] [10:28:16]: Started ServerConnector@6f3a19ad{HTTP/1.1,[http/1.1]}{0.0.0.0:8088}
INFO | jvm 1 | 2021/01/03 13:28:16 | I [o.e.j.s.Server ] [10:28:16]: Started @3013ms
INFO | jvm 1 | 2021/01/03 13:28:18 | WARNING: An illegal reflective access operation has occurred
INFO | jvm 1 | 2021/01/03 13:28:18 | WARNING: Illegal reflective access by com.inductiveautomation.ignition.gateway.util.IgnitionSocketImplFactory (file:/C:/Program%20Files/Inductive%20Automation/Ignition/lib/core/gateway/gateway-8.1.1.jar) to constructor java.net.SocksSocketImpl()
INFO | jvm 1 | 2021/01/03 13:28:18 | WARNING: Please consider reporting this to the maintainers of com.inductiveautomation.ignition.gateway.util.IgnitionSocketImplFactory
INFO | jvm 1 | 2021/01/03 13:28:18 | WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
INFO | jvm 1 | 2021/01/03 13:28:18 | WARNING: All illegal access operations will be denied in a future release
INFO | jvm 1 | 2021/01/03 13:28:55 | I [o.e.j.s.AbstractConnector ] [10:28:55]: Started ServerConnector@1191eaae{SSL,[ssl, http/1.1]}{0.0.0.0:8060}
INFO | jvm 1 | 2021/01/03 13:28:55 | I [o.e.j.s.h.ContextHandler ] [10:28:55]: Stopped o.e.j.w.WebAppContext@4c85a985{Commissioning,/,file:///C:/Program%20Files/Inductive%20Automation/Ignition/webserver/webapps/commissioning/,UNAVAILABLE}
INFO | jvm 1 | 2021/01/03 13:28:55 | I [Commissioning ] [10:28:55]: Commissioning State updated from needs_commıssıonıng to commıssıoned
INFO | jvm 1 | 2021/01/03 13:28:55 | I [o.a.w.Application ] [10:28:55]: [WicketFilter] init: Wicket core library initializer
INFO | jvm 1 | 2021/01/03 13:28:55 | I [o.a.w.RequestListenerInterface] [10:28:55]: registered listener interface [RequestListenerInterface name=IBehaviorListener, method=public abstract void org.apache.wicket.behavior.IBehaviorListener.onRequest()]
INFO | jvm 1 | 2021/01/03 13:28:55 | I [o.a.w.RequestListenerInterface] [10:28:55]: registered listener interface [RequestListenerInterface name=IFormSubmitListener, method=public abstract void org.apache.wicket.markup.html.form.IFormSubmitListener.onFormSubmitted()]
INFO | jvm 1 | 2021/01/03 13:28:55 | I [o.a.w.RequestListenerInterface] [10:28:55]: registered listener interface [RequestListenerInterface name=ILinkListener, method=public abstract void org.apache.wicket.markup.html.link.ILinkListener.onLinkClicked()]
INFO | jvm 1 | 2021/01/03 13:28:55 | I [o.a.w.RequestListenerInterface] [10:28:55]: registered listener interface [RequestListenerInterface name=IOnChangeListener, method=public abstract void org.apache.wicket.markup.html.form.IOnChangeListener.onSelectionChanged()]
INFO | jvm 1 | 2021/01/03 13:28:55 | I [o.a.w.RequestListenerInterface] [10:28:55]: registered listener interface [RequestListenerInterface name=IRedirectListener, method=public abstract void org.apache.wicket.IRedirectListener.onRedirect()]
INFO | jvm 1 | 2021/01/03 13:28:55 | I [o.a.w.RequestListenerInterface] [10:28:55]: registered listener interface [RequestListenerInterface name=IResourceListener, method=public abstract void org.apache.wicket.IResourceListener.onResourceRequested()]
INFO | jvm 1 | 2021/01/03 13:28:55 | I [o.a.w.Application ] [10:28:55]: [WicketFilter] init: Wicket extensions initializer
INFO | jvm 1 | 2021/01/03 13:28:55 | I [IgnitionGateway ] [10:28:55]: Ignition[state=STOPPED] ContextState = STARTING
INFO | jvm 1 | 2021/01/03 13:28:55 | I [o.a.w.p.h.WebApplication ] [10:28:55]: [WicketFilter] Started Wicket version 6.1.1 in DEPLOYMENT mode
INFO | jvm 1 | 2021/01/03 13:28:55 | I [IgnitionGateway ] [10:28:55]: Starting Ignition 8.1.1 (b2020120808)
INFO | jvm 1 | 2021/01/03 13:28:55 | I [IgnitionGateway ] [10:28:55]: Reloading JDBC classloader.
INFO | jvm 1 | 2021/01/03 13:28:55 | I [o.e.j.s.h.ContextHandler ] [10:28:55]: Started c.i.c.MainWebAppContext@7e5dadb3{Ignition,/,file:///C:/Program%20Files/Inductive%20Automation/Ignition/webserver/webapps/main/,AVAILABLE}
INFO | jvm 1 | 2021/01/03 13:28:55 | I [R.S.S.InternalDb ] [10:28:55]: Internal db synchronizer disk cache initialized. State id=null
INFO | jvm 1 | 2021/01/03 13:28:55 | I [R.StateMonitoring ] [10:28:55]: Redundancy state changed: Role=Independent, Activity level=Active, Project state=Good, History level=Full
INFO | jvm 1 | 2021/01/03 13:28:55 | I [g.InternalDatabaseManager ] [10:28:55]: Starting up...
INFO | jvm 1 | 2021/01/03 13:28:55 | I [P.InternalDatabase ] [10:28:55]: Looking for existing internal database "config.idb"...
INFO | jvm 1 | 2021/01/03 13:28:55 | I [P.InternalDatabase ] [10:28:55]: ... no files found, will create.
INFO | jvm 1 | 2021/01/03 13:28:55 | I [P.InternalDatabase ] [10:28:55]: Creating new internal database "config.idb".
INFO | jvm 1 | 2021/01/03 13:28:56 | I [g.InternalDatabaseManager ] [10:28:56]: Upgrading schema for module "ignition"
INFO | jvm 1 | 2021/01/03 13:28:56 | I [P.InternalDatabase ] [10:28:56]: internal database "config.idb" started up successfully.
INFO | jvm 1 | 2021/01/03 13:28:56 | I [P.InternalDatabase ] [10:28:56]: Registering autobackup task [owner=Internal DB Autobackup, name=internal database "config.idb"]
INFO | jvm 1 | 2021/01/03 13:28:56 | I [g.ModuleManager ] [10:28:56]: Loading modules....
INFO | jvm 1 | 2021/01/03 13:29:00 | I [A.Notification ] [10:29:00]: Alert notification system created.
INFO | jvm 1 | 2021/01/03 13:29:03 | I [g.PersistentRecordSecurityLevelConfigService] [10:29:03]: Set up in 306 ms
INFO | jvm 1 | 2021/01/03 13:29:04 | I [g.InternalDatabaseManager ] [10:29:04]: Upgrading schema for module "ignition"
INFO | jvm 1 | 2021/01/03 13:29:05 | I [g.PersistentRecordIdpAdapterConfigService] [10:29:05]: Successfully added new Identity Provider with name "default" from User Source Profile
INFO | jvm 1 | 2021/01/03 13:29:05 | I [g.PersistentRecordIdpAdapterConfigService] [10:29:05]: Set up in 1213 ms
INFO | jvm 1 | 2021/01/03 13:29:05 | I [g.InternalDatabaseManager ] [10:29:05]: Upgrading schema for module "ignition"
INFO | jvm 1 | 2021/01/03 13:29:05 | I [g.PersistentRecordIdpAdapterMetricsService] [10:29:05]: Legacy User History Table not found.
INFO | jvm 1 | 2021/01/03 13:29:05 | I [g.PersistentRecordIdpAdapterMetricsService] [10:29:05]: Set up in 576 ms
INFO | jvm 1 | 2021/01/03 13:29:06 | I [IgnitionGateway ] [10:29:05]: System properties does not exist in IDB. Creating default system properties...
INFO | jvm 1 | 2021/01/03 13:29:06 | I [g.InternalDatabaseManager ] [10:29:06]: Upgrading schema for module "ignition"
INFO | jvm 1 | 2021/01/03 13:29:06 | I [IgnitionGateway ] [10:29:06]: Upgrading setting 'ConfigRoleName' with value 'Administrator' to 'ConfigPermissions' with value '{"type":"AnyOf","securityLevels":[{"name":"Authenticated","description":"Represents a user who has been authenticated by the system.","children":[{"name":"Roles","description":"Represents the roles that a user has.","children":[{"name":"Administrator","children":[]}]}]}]}'
INFO | jvm 1 | 2021/01/03 13:29:06 | I [IgnitionGateway ] [10:29:06]: Upgrading setting 'StatusPageRoleName' with value 'Administrator' to 'StatusPagePermissions' with value '{"type":"AnyOf","securityLevels":[{"name":"Authenticated","description":"Represents a user who has been authenticated by the system.","children":[{"name":"Roles","description":"Represents the roles that a user has.","children":[{"name":"Administrator","children":[]}]}]}]}'
INFO | jvm 1 | 2021/01/03 13:29:06 | I [IgnitionGateway ] [10:29:06]: Upgrading setting 'HomePageRoleName' with value '' to 'HomePagePermissions' with value '{"type":"AnyOf","securityLevels":[]}'
INFO | jvm 1 | 2021/01/03 13:29:06 | I [IgnitionGateway ] [10:29:06]: Upgrading setting 'DesignerRoleName' with value 'Administrator' to 'DesignerPermissions' with value '{"type":"AnyOf","securityLevels":[{"name":"Authenticated","description":"Represents a user who has been authenticated by the system.","children":[{"name":"Roles","description":"Represents the roles that a user has.","children":[{"name":"Administrator","children":[]}]}]}]}'
INFO | jvm 1 | 2021/01/03 13:29:06 | I [IgnitionGateway ] [10:29:06]: Upgrading setting 'CreateProjectRoleName' with value '' to 'CreateProjectPermissions' with value '{"type":"AnyOf","securityLevels":[]}'
INFO | jvm 1 | 2021/01/03 13:29:06 | I [IgnitionGateway ] [10:29:06]: 1 rows affected
INFO | jvm 1 | 2021/01/03 13:29:07 | I [g.InternalDatabaseRememberedSubjects] [10:29:07]: Set up in 273 ms
INFO | jvm 1 | 2021/01/03 13:29:07 | I [g.OIDCProviderManager ] [10:29:07]: Set up in 274 ms
INFO | jvm 1 | 2021/01/03 13:29:08 | I [g.InternalDatabaseManager ] [10:29:07]: Upgrading schema for module ""
INFO | jvm 1 | 2021/01/03 13:29:08 | I [MetricHistoryManager ] [10:29:08]: Creating new metrics database
INFO | jvm 1 | 2021/01/03 13:29:10 | W [g.LicenseManager ] [10:29:10]: Could not read license from HASP key. HASP login() failed. Last error = 7.
INFO | jvm 1 | 2021/01/03 13:29:12 | I [g.InternalDatabaseManager ] [10:29:11]: Upgrading schema for module "ignition"
INFO | jvm 1 | 2021/01/03 13:29:14 | I [t.m.provider ] [10:29:14]: Creating new tag store for provider 'System'.
INFO | jvm 1 | 2021/01/03 13:29:16 | I [t.s.internaljson ] [10:29:16]: Redundancy version token not set for provider 'System', will initialize to system version. provider=System
INFO | jvm 1 | 2021/01/03 13:29:17 | I [g.InternalDatabaseManager ] [10:29:17]: Upgrading schema for module ""
INFO | jvm 1 | 2021/01/03 13:29:19 | I [m.M.Routing ] [10:29:19]: Setting max proxy route depth = 1
INFO | jvm 1 | 2021/01/03 13:29:19 | I [c.i.i.g.p.r.ProjectRecordConverter] [10:29:19]: Conversion finished. Elapsed time: 25 ms
INFO | jvm 1 | 2021/01/03 13:29:19 | E [C.BasicExecutionEngine ] [10:29:19]: One-shot task com.inductiveautomation.ignition.gateway.IgnitionGateway$$Lambda$407/0x00000001004a2040@786bd703 threw uncaught exception.
INFO | jvm 1 | 2021/01/03 13:29:19 | java.lang.ExceptionInInitializerError: null
INFO | jvm 1 | 2021/01/03 13:29:19 | at org.python.core.PyType.init(PyType.java:686)
INFO | jvm 1 | 2021/01/03 13:29:19 | at org.python.core.PyType.createType(PyType.java:1573)
INFO | jvm 1 | 2021/01/03 13:29:19 | at org.python.core.PyType.addFromClass(PyType.java:1508)
INFO | jvm 1 | 2021/01/03 13:29:19 | at org.python.core.PyType.fromClass(PyType.java:1609)
INFO | jvm 1 | 2021/01/03 13:29:19 | at org.python.core.PyType.fromClass(PyType.java:1587)
INFO | jvm 1 | 2021/01/03 13:29:19 | at org.python.core.PyStringMap.getLazyType(PyStringMap.java:68)
INFO | jvm 1 | 2021/01/03 13:29:19 | at org.python.core.PyStringMap.<init>(PyStringMap.java:48)
INFO | jvm 1 | 2021/01/03 13:29:19 | at org.python.core.PyStringMap.<init>(PyStringMap.java:44)
INFO | jvm 1 | 2021/01/03 13:29:19 | at org.python.expose.BaseTypeBuilder.getDict(BaseTypeBuilder.java:49)
INFO | jvm 1 | 2021/01/03 13:29:19 | at org.python.core.PyType.init(PyType.java:674)
INFO | jvm 1 | 2021/01/03 13:29:19 | at org.python.core.PyType.addBuilder(PyType.java:1498)
INFO | jvm 1 | 2021/01/03 13:29:19 | at org.python.core.PyType.<clinit>(PyType.java)
INFO | jvm 1 | 2021/01/03 13:29:19 | at org.python.core.PyObject.<init>(PyObject.java:93)
INFO | jvm 1 | 2021/01/03 13:29:19 | at org.python.core.PyBuiltinCallable.<init>(PyBuiltinCallable.java:22)
INFO | jvm 1 | 2021/01/03 13:29:19 | at org.python.core.PyBuiltinMethod.<init>(PyBuiltinMethod.java:16)
INFO | jvm 1 | 2021/01/03 13:29:19 | at org.python.core.PyBuiltinMethodNarrow.<init>(PyBuiltinMethodNarrow.java:23)
INFO | jvm 1 | 2021/01/03 13:29:19 | at org.python.core.PyDataDescr$getset_descriptor___get___exposer.<init>(Unknown Source)
INFO | jvm 1 | 2021/01/03 13:29:19 | at org.python.core.PyDataDescr$PyExposer.<init>(Unknown Source)
INFO | jvm 1 | 2021/01/03 13:29:19 | at org.python.core.PyDataDescr.<clinit>(PyDataDescr.java)
INFO | jvm 1 | 2021/01/03 13:29:19 | at org.python.core.PyBuiltinCallable$PyExposer.<init>(Unknown Source)
INFO | jvm 1 | 2021/01/03 13:29:19 | at org.python.core.PyBuiltinCallable.<clinit>(PyBuiltinCallable.java)
INFO | jvm 1 | 2021/01/03 13:29:19 | at org.python.core.PyObject$PyExposer.<init>(Unknown Source)
INFO | jvm 1 | 2021/01/03 13:29:19 | at org.python.core.PyObject.<clinit>(PyObject.java)
INFO | jvm 1 | 2021/01/03 13:29:19 | at com.inductiveautomation.ignition.common.script.ScriptManager.asynchInit(ScriptManager.java:205)
INFO | jvm 1 | 2021/01/03 13:29:19 | at com.inductiveautomation.ignition.common.script.ScriptManager.<init>(ScriptManager.java:116)
INFO | jvm 1 | 2021/01/03 13:29:19 | at com.inductiveautomation.ignition.gateway.IgnitionGateway.createScriptManager(IgnitionGateway.java:1308)
INFO | jvm 1 | 2021/01/03 13:29:19 | at com.inductiveautomation.ignition.gateway.script.GatewayScriptManagerHolder.initializeBeforeModuleSetup(GatewayScriptManagerHolder.java:67)
INFO | jvm 1 | 2021/01/03 13:29:19 | at com.inductiveautomation.ignition.gateway.IgnitionGateway.startupInternal(IgnitionGateway.java:1055)
INFO | jvm 1 | 2021/01/03 13:29:19 | at com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl.startup(RedundancyManagerImpl.java:293)
INFO | jvm 1 | 2021/01/03 13:29:19 | at com.inductiveautomation.ignition.gateway.IgnitionGateway.initRedundancy(IgnitionGateway.java:724)
INFO | jvm 1 | 2021/01/03 13:29:19 | at com.inductiveautomation.ignition.gateway.IgnitionGateway.lambda$initInternal$0(IgnitionGateway.java:658)
INFO | jvm 1 | 2021/01/03 13:29:19 | at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:518)
INFO | jvm 1 | 2021/01/03 13:29:19 | at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
INFO | jvm 1 | 2021/01/03 13:29:19 | at java.base/java.util.concurrent.FutureTask.run(Unknown Source)
INFO | jvm 1 | 2021/01/03 13:29:19 | at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
INFO | jvm 1 | 2021/01/03 13:29:19 | at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
INFO | jvm 1 | 2021/01/03 13:29:19 | at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
INFO | jvm 1 | 2021/01/03 13:29:19 | at java.base/java.lang.Thread.run(Unknown Source)
INFO | jvm 1 | 2021/01/03 13:29:19 | Caused by: java.lang.IllegalArgumentException: Cannot create PyString with non-byte value
INFO | jvm 1 | 2021/01/03 13:29:19 | at org.python.core.PyString.<init>(PyString.java:57)
INFO | jvm 1 | 2021/01/03 13:29:19 | at org.python.core.PyString.<init>(PyString.java:70)
INFO | jvm 1 | 2021/01/03 13:29:19 | at org.python.core.PyString.<init>(PyString.java:74)
INFO | jvm 1 | 2021/01/03 13:29:19 | at org.python.core.Py.newString(Py.java:647)
INFO | jvm 1 | 2021/01/03 13:29:19 | at org.python.core.PyJavaType.init(PyJavaType.java:585)
INFO | jvm 1 | 2021/01/03 13:29:19 | at org.python.core.PySingleton.<init>(PySingleton.java:9)
INFO | jvm 1 | 2021/01/03 13:29:19 | at org.python.core.PyNotImplemented.<init>(PyNotImplemented.java:10)
INFO | jvm 1 | 2021/01/03 13:29:19 | at org.python.core.Py.<clinit>(Py.java:94)
INFO | jvm 1 | 2021/01/03 13:29:19 | ... 38 common frames omitted
