Ignition version used to create a backup gateway
Hello everybody.
is possibile to know which version of ignition is been used from a Ignition Backup gateway file (.gwbk file)
Thank you very much
Andrea
Are you trying to see the Ignition version that was used to create the backup? If so, you can open the .gwbk file with a program like 7-Zip (since the .gwbk is a glorified zip file). Open backupinfo.xml, and the Ignition version that created the backup is listed in there.
Hi
Thank you very much
:thumb_right:
