Hello! I was wondering how can i configure the vision client launcher such that when a user clicks it automatically takes to my desired application without having to 'add' or edit applications
You can right-click and create a shortcut, it will appear on your desktop and you can launch it instead.
P.S. Also you can add this shortcut to startup folder and it will run automatically on a win startup.
Add an app to run automatically at startup in Windows 10 - Microsoft Support
You can also deploy the launcher via IT/management tools with a preconfigured launcher JSON next to the install:
https://docs.inductiveautomation.com/display/DOC81/Vision+Client+Launcher+Settings#VisionClientLauncherSettings-LauncherConfigurationUsingJSON
In a Windows environment, you can also take advantage of the MSI installers we provide:
https://docs.inductiveautomation.com/display/DOC81/Launchers+and+Workstation#LaunchersandWorkstation-HostedLauncherInstallers
