Ignition Vision - close popup outside the box
Is there a way to do this on vision, I want to close a popup window if I press anywhere outside the popup window instead of using the close button.
I can't test at the moment but try creating a script on your window that uses internalFrameDeactivated to close itself
Thanks, it totally worked.
Here is the script I used:
