Ignition Vision Designer 8.1.31 - Alarm Pipelines UI Issues
Hello, I'm not sure if this is a bug or a design limitation currently. But when creating alarm pipelines, one issue I have is there is no way to zoom in or out easily within the designer which makes it hard to work on larger pipelines when trying to keep them from being too cluttered. I can control the zoom by using CTRL + scrollwheel combination on mouse, but then the second issue I noticed pops up. Whenever I zoom out in this way with the CTRL + scrollwheel combination, I can no longer draw paths between blocks until I close the pipeline and open it again, which also resizes the pipeline window to a default size, smaller than my current pipeline area. Also if I try to resize the pipeline with by dragging the borders while zoomed out this way. It snaps back to default size as well. Is there something I'm missing here or is this maybe a bug that is occurring during these circumstances. I am on Ignition version 8.1.31. Designer version 1.1.31.
Thanks.
Hello,
Thank you for reporting this issue. This is a known issue and a bug ticket has been created. This post will be added to the ticket to increase it's visibility. When the issue is resolved this thread will be notified.
Thank you. I will keep an eye out for updates on the thread. Looking forward to it being fixed, will definitely provide easier use of the pipeline UI.
