Ignition Vision Users edition
Hello,
I'm in the process of migrating a Vision project to Perspective. In my Vision project, I can clearly see the users, their categories, roles, and privileges:
However, when I look at the Gateway settings, it shows no users:
Why might this be happening? Could it be that the project is running and retaining old user data, or is it possible that I'm pointing to a different Gateway?
Is there a way I can find the right gateway port?
Check the user source that your 'user management' component is pointed at, in the Vision project.
Thanks PGriffith, that was it, I edit the project in the gateway and found the Authentification Profeli linked to it
Then go back to the Users and found it.
Thank you!
