Ignition will track changes made to the Designer
Hi ,
The below reference from the user manual on the audit profile stated that changes in the designer can be tracked as audit project events.
I have tried to remove some of the components in the designer but it does not update these changes into the audit event logs. All I can see from the database query browser are log in/out status or tag changes. Project save and publish are also not logged in the audit profile.
I have already checked the enable auditing from the project properties.
Thanks.
What version of ignition are you using?
Edit: probably the same one now as you were using 11 months ago… My bad
