Hello,
I have a little configuration problem, how can I make an ingnition window reducible in size so that it's not full screen all the time?
Your question mentions "window" so I've added the vision tag.
In the project's launch properties, you can select whether to allow full-screen mode, windowed mode, or both, and if both, which is default. You would then alter the shortcut in your Vision Client Launcher to use your preference.
You have to change the launcher shortcut too.
