Ignition with Machine Learning
Hi, my name is Kenneth, I am working with Ignition Machine Learning Manager and I have historical tag data (temperature and humidity) collected over several months.
My goal is to build a model that can predict future values (for example, predicting temperature 10 minutes ahead) based on current and past data.
Currently, I am able to:
  • Retrieve tag history data
  • Train a regression model (OLS Multiple Linear Regression)
However, I am unsure about the correct way to structure the dataset for time-based predictions.
So I am working and creating models with this Ignition Machine Learning Manager What type of algorithm can I use to train a model entirely within Ignition, without depending on external systems?
What I need is to create a trained model that can be read directly by Ignition or through a tag, and use it to visualize or predict values some time into the future—for example, 10 minutes ahead of real-time data.
I believe this could be achieved using the Machine Learning Manager by creating and deploying a model within Ignition itself. Could you please guide me on the best approach or recommended algorithms for this use case?
Any help would be greatly appreciated. Thank you in advance.
Double posting is against the forum's rules. Give your first post some time to simmer. If you haven't heard anything in a few days then you can self bump your post. The people here are volunteers and respond in their free time.
Picking Ignition Machine Learning as the winner
