Ignition would not start on ubuntu after reboot
Ignition worked the first time only after reboot I get the following error. My wrapper log file is attached:
STATUS | wrapper | 2023/06/09 12:14:35 | --> Wrapper Started as Daemon
STATUS | wrapper | 2023/06/09 12:14:35 | Java Service Wrapper Standard Edition 64-bit 3.5.42
STATUS | wrapper | 2023/06/09 12:14:35 | Copyright (C) 1999-2020 Tanuki Software, Ltd. All Rights Reserved.
STATUS | wrapper | 2023/06/09 12:14:35 | http://wrapper.tanukisoftware.com
STATUS | wrapper | 2023/06/09 12:14:35 | Licensed to Inductive Automation for Inductive Automation
STATUS | wrapper | 2023/06/09 12:14:42 | Launching a JVM...
INFO | jvm 1 | 2023/06/09 12:14:44 | WrapperManager: Initializing...
ERROR | wrapper | 2023/06/09 12:15:12 | Startup failed: Timed out waiting for a signal from the JVM.
ERROR | wrapper | 2023/06/09 12:15:13 | JVM did not exit on request, termination requested.
STATUS | wrapper | 2023/06/09 12:15:13 | JVM received a signal SIGKILL (9).
STATUS | wrapper | 2023/06/09 12:15:13 | JVM process is gone.
STATUS | wrapper | 2023/06/09 12:15:13 | JVM exited after being requested to terminate.
STATUS | wrapper | 2023/06/09 12:15:18 | Reloading Wrapper configuration...
STATUS | wrapper | 2023/06/09 12:15:18 | JVM process is gone.
STATUS | wrapper | 2023/06/09 12:15:18 | Launching a JVM...
INFO | jvm 2 | 2023/06/09 12:15:18 | WrapperManager: Initializing...
INFO | jvm 2 | 2023/06/09 12:15:20 | WrapperManager Error: Failed to connect to the Wrapper at port 32,000. Cause: java.net.ConnectException: Connection refused (Connection refused)
INFO | jvm 2 | 2023/06/09 12:15:20 | WrapperManager Error: Exiting JVM...
ERROR | wrapper | 2023/06/09 12:15:20 | JVM exited while loading the application.
STATUS | wrapper | 2023/06/09 12:15:26 | Reloading Wrapper configuration...
STATUS | wrapper | 2023/06/09 12:15:26 | JVM process is gone.
STATUS | wrapper | 2023/06/09 12:15:26 | Launching a JVM...
INFO | jvm 3 | 2023/06/09 12:15:26 | WrapperManager: Initializing...
INFO | jvm 3 | 2023/06/09 12:15:27 | WrapperManager Error: Failed to connect to the Wrapper at port 32,000. Cause: java.net.ConnectException: Connection refused (Connection refused)
INFO | jvm 3 | 2023/06/09 12:15:27 | WrapperManager Error: Exiting JVM...
ERROR | wrapper | 2023/06/09 12:15:28 | JVM exited while loading the application.
STATUS | wrapper | 2023/06/09 12:15:33 | Reloading Wrapper configuration...
STATUS | wrapper | 2023/06/09 12:15:33 | JVM process is gone.
STATUS | wrapper | 2023/06/09 12:15:33 | Launching a JVM...
INFO | jvm 4 | 2023/06/09 12:15:33 | WrapperManager: Initializing...
INFO | jvm 4 | 2023/06/09 12:15:35 | WrapperManager Error: Failed to connect to the Wrapper at port 32,000. Cause: java.net.ConnectException: Connection refused (Connection refused)
INFO | jvm 4 | 2023/06/09 12:15:35 | WrapperManager Error: Exiting JVM...
ERROR | wrapper | 2023/06/09 12:15:35 | JVM exited while loading the application.
STATUS | wrapper | 2023/06/09 12:15:40 | Reloading Wrapper configuration...
STATUS | wrapper | 2023/06/09 12:15:41 | JVM process is gone.
STATUS | wrapper | 2023/06/09 12:15:41 | Launching a JVM...
INFO | jvm 5 | 2023/06/09 12:15:41 | WrapperManager: Initializing...
INFO | jvm 5 | 2023/06/09 12:15:42 | WrapperManager Error: Failed to connect to the Wrapper at port 32,000. Cause: java.net.ConnectException: Connection refused (Connection refused)
INFO | jvm 5 | 2023/06/09 12:15:42 | WrapperManager Error: Exiting JVM...
ERROR | wrapper | 2023/06/09 12:15:43 | JVM exited while loading the application.
FATAL | wrapper | 2023/06/09 12:15:43 | There were 5 failed launches in a row, each lasting less than 300 seconds. Giving up.
FATAL | wrapper | 2023/06/09 12:15:43 | There may be a configuration problem: please check the logs.
STATUS | wrapper | 2023/06/09 12:15:44 | <-- Wrapper Stopped
STATUS | wrapper | 2023/06/22 09:04:09 | --> Wrapper Started as Console
STATUS | wrapper | 2023/06/22 09:04:09 | Java Service Wrapper Standard Edition 64-bit 3.5.42
STATUS | wrapper | 2023/06/22 09:04:09 | Copyright (C) 1999-2020 Tanuki Software, Ltd. All Rights Reserved.
STATUS | wrapper | 2023/06/22 09:04:09 | http://wrapper.tanukisoftware.com
STATUS | wrapper | 2023/06/22 09:04:09 | Licensed to Inductive Automation for Inductive Automation
STATUS | wrapper | 2023/06/22 09:04:17 | Launching a JVM...
INFO | jvm 1 | 2023/06/22 09:04:19 | WrapperManager: Initializing...
ERROR | wrapper | 2023/06/22 09:04:48 | Startup failed: Timed out waiting for a signal from the JVM.
ERROR | wrapper | 2023/06/22 09:04:48 | JVM did not exit on request, termination requested.
STATUS | wrapper | 2023/06/22 09:04:48 | JVM received a signal SIGKILL (9).
STATUS | wrapper | 2023/06/22 09:04:48 | JVM process is gone.
STATUS | wrapper | 2023/06/22 09:04:48 | JVM exited after being requested to terminate.
STATUS | wrapper | 2023/06/22 09:04:53 | Reloading Wrapper configuration...
STATUS | wrapper | 2023/06/22 09:04:53 | JVM process is gone.
STATUS | wrapper | 2023/06/22 09:04:54 | Launching a JVM...
INFO | jvm 2 | 2023/06/22 09:04:54 | WrapperManager: Initializing...
INFO | jvm 2 | 2023/06/22 09:04:57 | WrapperManager Error: Failed to connect to the Wrapper at port 32,000. Cause: java.net.ConnectException: Connection refused (Connection refused)
INFO | jvm 2 | 2023/06/22 09:04:57 | WrapperManager Error: Exiting JVM...
ERROR | wrapper | 2023/06/22 09:04:57 | JVM exited while loading the application.
STATUS | wrapper | 2023/06/22 09:05:03 | Reloading Wrapper configuration...
STATUS | wrapper | 2023/06/22 09:05:03 | JVM process is gone.
STATUS | wrapper | 2023/06/22 09:05:03 | Launching a JVM...
INFO | jvm 3 | 2023/06/22 09:05:03 | WrapperManager: Initializing...
INFO | jvm 3 | 2023/06/22 09:05:04 | WrapperManager Error: Failed to connect to the Wrapper at port 32,000. Cause: java.net.ConnectException: Connection refused (Connection refused)
INFO | jvm 3 | 2023/06/22 09:05:04 | WrapperManager Error: Exiting JVM...
ERROR | wrapper | 2023/06/22 09:05:05 | JVM exited while loading the application.
STATUS | wrapper | 2023/06/22 09:05:10 | Reloading Wrapper configuration...
STATUS | wrapper | 2023/06/22 09:05:10 | JVM process is gone.
STATUS | wrapper | 2023/06/22 09:05:10 | Launching a JVM...
INFO | jvm 4 | 2023/06/22 09:05:11 | WrapperManager: Initializing...
INFO | jvm 4 | 2023/06/22 09:05:12 | WrapperManager Error: Failed to connect to the Wrapper at port 32,000. Cause: java.net.ConnectException: Connection refused (Connection refused)
INFO | jvm 4 | 2023/06/22 09:05:12 | WrapperManager Error: Exiting JVM...
ERROR | wrapper | 2023/06/22 09:05:13 | JVM exited while loading the application.
STATUS | wrapper | 2023/06/22 09:05:18 | Reloading Wrapper configuration...
STATUS | wrapper | 2023/06/22 09:05:18 | JVM process is gone.
STATUS | wrapper | 2023/06/22 09:05:18 | Launching a JVM...
INFO | jvm 5 | 2023/06/22 09:05:19 | WrapperManager: Initializing...
INFO | jvm 5 | 2023/06/22 09:05:20 | WrapperManager Error: Failed to connect to the Wrapper at port 32,000. Cause: java.net.ConnectException: Connection refused (Connection refused)
INFO | jvm 5 | 2023/06/22 09:05:20 | WrapperManager Error: Exiting JVM...
ERROR | wrapper | 2023/06/22 09:05:20 | JVM exited while loading the application.
FATAL | wrapper | 2023/06/22 09:05:21 | There were 5 failed launches in a row, each lasting less than 300 seconds. Giving up.
FATAL | wrapper | 2023/06/22 09:05:21 | There may be a configuration problem: please check the logs.
STATUS | wrapper | 2023/06/22 09:05:21 | <-- Wrapper Stopped
Is this a really big application? I sometime have to increase the startup time allowance in the wrapper.
