Ignition8 Launcher for All Users
I’m working on upgrading to v8. We access Ignition via a Citrix environment. So I need an easy shortcut to roll out to all users.
With the v7 launcher, I could specify the project and gateway via the command line:
clientlauncher.exe project=myProject gateway.addr=myserver:8088/main
This worked great. I can’t find an equivalent in the v8 launcher.
On v8, I see how to put the clientlauncher-data folder into a zip file and deploy it - but it appears to still require it be installed into the User’s profile folder. I can’t just run it from any location. Normally I would just put the whole works in program files and make a shortcut to it, but the launcher doesn’t seem to “see” the config files there.
Any ideas?
Folks have already discussed a similar issue, see ( colon here can provoke emoji )
You would need to click on the Blue Link above to read the rest, or enter
http://forum.inductiveautomation.com/t/launch-client-without-client-launcher/23136
The only other idea I have for you is to try the weather in Phoenix, sorry.
(2095 Ivy Avenue East, St.Paul, Mn. ex-owner many years ago).
