When I am in the designer using preview mode and click a component in the project browser I receive the following error message. all components will cause the error except the window and the root container.
[code]java.lang.ClassCastException: com.inductiveautomation.ignition.designer.IgnitionDesigner cannot be cast to javax.swing.JComponent
at com.inductiveautomation.factorypmi.application.components.util.FPMILayout.getOffsettingParent(FPMILayout.java:577)
at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace$Delegate.getOffsettingParent(WindowWorkspace.java:2720)
at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace$Delegate.convertRectSpecial(WindowWorkspace.java:2673)
at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace$Delegate.getBounds(WindowWorkspace.java:2653)
at com.inductiveautomation.ignition.designer.designable.tools.SelectionTool.getStatusBarText(SelectionTool.java:393)
at com.inductiveautomation.ignition.designer.designable.AbstractDesignableWorkspace.updateStatusBarText(AbstractDesignableWorkspace.java:157)
at com.inductiveautomation.ignition.designer.designable.AbstractDesignableWorkspace$3.itemSelectionChanged(AbstractDesignableWorkspace.java:134)
at com.inductiveautomation.ignition.designer.designable.AbstractDesignableWorkspace.fireSelectedItemsChanged(AbstractDesignableWorkspace.java:261)
at com.inductiveautomation.ignition.designer.designable.AbstractDesignableWorkspace.setSelectedItems(AbstractDesignableWorkspace.java:244)
at com.inductiveautomation.factorypmi.designer.model.navtree.AbstractTopLevelContainerNode.onChildrenSelected(AbstractTopLevelContainerNode.java:275)
at com.inductiveautomation.ignition.designer.navtree.model.AbstractNavTreeNode.dispatchSelectionEvent(AbstractNavTreeNode.java:624)
at com.inductiveautomation.ignition.designer.navtree.model.AbstractNavTreeNode.dispatchSelectionEvent(AbstractNavTreeNode.java:620)
at com.inductiveautomation.ignition.designer.navtree.NavTreePanel$SelectionListener.valueChanged(NavTreePanel.java:437)
at javax.swing.JTree.fireValueChanged(Unknown Source)
at javax.swing.JTree$TreeSelectionRedirector.valueChanged(Unknown Source)
at javax.swing.tree.DefaultTreeSelectionModel.fireValueChanged(Unknown Source)
at javax.swing.tree.DefaultTreeSelectionModel.notifyPathChange(Unknown Source)
at javax.swing.tree.DefaultTreeSelectionModel.setSelectionPaths(Unknown Source)
at javax.swing.tree.DefaultTreeSelectionModel.setSelectionPath(Unknown Source)
at javax.swing.JTree.setSelectionPath(Unknown Source)
at javax.swing.plaf.basic.BasicTreeUI.selectPathForEvent(Unknown Source)
at javax.swing.plaf.basic.BasicTreeUI$Handler.handleSelection(Unknown Source)
at javax.swing.plaf.basic.BasicTreeUI$Handler.mousePressedDND(Unknown Source)
at javax.swing.plaf.basic.BasicTreeUI$Handler.mousePressed(Unknown Source)
at java.awt.AWTEventMulticaster.mousePressed(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at com.jidesoft.docking.b.a(Unknown Source)
at com.jidesoft.docking.DefaultDockingManager.handleEvent(Unknown Source)
at com.jidesoft.docking.DefaultDockingManager$49.eventDispatched(Unknown Source)
at java.awt.Toolkit$SelectiveAWTEventListener.eventDispatched(Unknown Source)
at java.awt.Toolkit$ToolkitEventMulticaster.eventDispatched(Unknown Source)
at java.awt.Toolkit.notifyAWTEventListeners(Unknown Source)
at java.awt.KeyboardFocusManager.redispatchEvent(Unknown Source)
at java.awt.DefaultKeyboardFocusManager.typeAheadAssertions(Unknown Source)
at java.awt.DefaultKeyboardFocusManager.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$000(Unknown Source)
at java.awt.EventQueue$1.run(Unknown Source)
at java.security.AccessControlContext$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$2.run(Unknown Source)
at java.awt.SequencedEvent.dispatch(Unknown Source)
Ignition v7.5.2 (b1146)
Java: Sun Microsystems Inc. 1.6.0_33
[/code]
