Local storage is stuck > 100%. I think it is interfering with the use of system.tag.storeTagHistory when importing data (migrating data) as I have little to no buffer to fill when importing. Thinking about reinstall but really would prefer a more surgical fix.
I've seen a few similar posts for vanilla Ignition with tag historian, but none of the solutions seem to fit. Anyway, thanks for any and all insight!
How many total data points do you have in your Edge historian? Limit is 35 days or 10 million entries, whichever comes first. The screenshot suggests you've hit the latter.
You should be deploying standard edition for such large history requirements.
I have multiple sites, with a local Ignition Edge install at each. The intent is to store and forward to headquarters where I have a standard install. I have no intent to store data locally at the edge.
I am using system.tag.storeTagHistory to import legacy data at the edge using scripting. My hope is that the data is forwarded with the same gateway identifier to make trending seamless from headquarters.
Is there any way to purge data after it is forwarded at the edge, or after a week or so? I cannot find any data purge settings for Ignition Edge. My local storage is full of data that probably already forwarded. Would it matter if I imported data out of sequence & from before the tag creation date?
When I import from the central gateway, I can change the provider name, but the tag historian wants to store the data with the local gateway name. The data exists, and all is well, but I would have to merge data from 2 tags to create a seamless trend of legacy and new data or multiplex the tags somehow based on age.
