Hello everyone, I currently have the following problem which I have not been able to locate.
I am running on an RPI Ignition Edge V8.1.37 and I want to connect to my HiveMQ cluster (using ssl) but no matter how much I try to configure the Mqtt Engine to integrate with the server, the connection does not work.
I am carrying out this same test on my PC with Ignition Maker V8.1.39 and it connects without problems.
I leave the RPI log here to see if any of you know what I am omitting.
Thank you
org.eclipse.paho.client.mqttv3.MqttException: MqttException
at org.eclipse.paho.client.mqttv3.internal.ExceptionHelper.createMqttException(ExceptionHelper.java:38)
at org.eclipse.paho.client.mqttv3.internal.ClientComms$ConnectBG.run(ClientComms.java:738)
Caused by: javax.net.ssl.SSLHandshakeException: PKIX path validation failed: java.security.cert.CertPathValidatorException: validity check failed
at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source)
at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source)
at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source)
at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source)
at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source)
at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source)
at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source)
at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source)
at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source)
at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source)
at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source)
at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source)
at org.eclipse.paho.client.mqttv3.internal.SSLNetworkModule.start(SSLNetworkModule.java:159)
at org.eclipse.paho.client.mqttv3.internal.ClientComms$ConnectBG.run(ClientComms.java:724)
... 1 common frames omitted
Caused by: sun.security.validator.ValidatorException: PKIX path validation failed: java.security.cert.CertPathValidatorException: validity check failed
at java.base/sun.security.validator.PKIXValidator.doValidate(Unknown Source)
at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source)
at java.base/sun.security.validator.Validator.validate(Unknown Source)
at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source)
at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source)
... 15 common frames omitted
Caused by: java.security.cert.CertPathValidatorException: validity check failed
at java.base/sun.security.provider.certpath.PKIXMasterCertPathValidator.validate(Unknown Source)
at java.base/sun.security.provider.certpath.PKIXCertPathValidator.validate(Unknown Source)
at java.base/sun.security.provider.certpath.PKIXCertPathValidator.engineValidate(Unknown Source)
at java.base/java.security.cert.CertPathValidator.validate(Unknown Source)
... 20 common frames omitted
Caused by: java.security.cert.CertificateNotYetValidException: NotBefore: Wed Jun 26 21:33:32 VET 2024
at java.base/sun.security.x509.CertificateValidity.valid(Unknown Source)
at java.base/sun.security.x509.X509CertImpl.checkValidity(Unknown Source)
at java.base/sun.security.provider.certpath.BasicChecker.verifyValidity(Unknown Source)
at java.base/sun.security.provider.certpath.BasicChecker.check(Unknown Source)
... 25 common frames omitted
