Igniton Audit Trial
Hello everyone, I need help to know how i can update the Ignition Audit Trail database for the Changes pushed directly from an Ignition Perspective client to a SQL database table.
I am on Ignition version 8.1.41 and working on Ignition Perspectie module.
How are you updating the SQL table from the perspective client, via a script? If so, use system.util.audit, which allows you to insert a record into the audit db manually. Its up to you to provide the data you want to track.
Thanks for the prompt response ryan. I am looking for some default option to get a row whenever any changes occurs from client to database. I am getting a resource modified row inserted whenever any changes happening from designer but the same behaviour is missing from client side. I am implementing this for one of my pharma client and i am afraid if the validation person doesn’t accept this manual insertion of row on every update. I got that there is a way with the script but is there any default option available which doesn’t involve scripting, just system generated. Thanks for hearing me out.
