Is there a way to have FSQL ignore the group trigger when the group is first turned on? I don’t want to write to the table just because I turned the group on.
EDIT:
For instance, I have a group for each machine that writes a time/date value to a table when the machine turns off. So I set the trigger to “Running” is = 0. So it’s works great if I turn the group on when the machine is running, but if I turn the group on when the machine is not currently running, it writes a value to the table. This falsely indicates that the machine just shut down, when in fact it may have shut down two weeks ago.
