Hello,
I am working with Ignition Edge on an Opto22 and occasionally I will get an error message on the Designer saying the following
java.util.concurrent.ExecutionException:
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: name-of-gateway
at java.base/java.util.concurrent.CompletableFuture.reportGet(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture.get(Unknown Source)
at com.inductiveautomation.ignition.designer.sqltags.opcbrowser.OpcBrowseExecutor$ProviderBrowseExecutor.browse(OpcBrowseExecutor.java:49)
at com.inductiveautomation.ignition.designer.sqltags.opcbrowser.AbstractOPCTreeNode.browse(AbstractOPCTreeNode.java:35)
at com.inductiveautomation.ignition.designer.sqltags.opcbrowser.OPCFolderNode.loadChildren(OPCFolderNode.java:52)
at com.inductiveautomation.ignition.client.util.gui.tree.AbstractAsynchronousTreeNode$Loader.run(AbstractAsynchronousTreeNode.java:82)
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: name-of-gateway
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:351)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:543)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:283)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:278)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invoke(GatewayInterface.java:954)
at com.inductiveautomation.ignition.client.tags.impl.GatewayTagInterface.browseTagDataSourcesAsync(GatewayTagInterface.java:178)
at com.inductiveautomation.ignition.client.tags.impl.GatewayTagInterface$GatewayProviderProxy.browseTagDataSourcesAsync(GatewayTagInterface.java:294)
at com.inductiveautomation.ignition.client.tags.impl.ClientTagManagerImpl.browseTagDataSourcesAsync(ClientTagManagerImpl.java:191)
... 9 more
Caused by: java.net.UnknownHostException: name-of-gateway
at java.base/java.net.AbstractPlainSocketImpl.connect(Unknown Source)
at java.base/java.net.SocksSocketImpl.connect(Unknown Source)
at java.base/java.net.Socket.connect(Unknown Source)
at java.base/sun.security.ssl.SSLSocketImpl.connect(Unknown Source)
at java.base/sun.net.NetworkClient.doConnect(Unknown Source)
at java.base/sun.net.www.http.HttpClient.openServer(Unknown Source)
at java.base/sun.net.www.protocol.https.HttpsClient.<init>(Unknown Source)
at java.base/sun.net.www.protocol.https.HttpsClient.New(Unknown Source)
at java.base/sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.getNewHttpClient(Unknown Source)
at java.base/sun.net.www.protocol.http.HttpURLConnection.plainConnect0(Unknown Source)
at java.base/sun.net.www.protocol.http.HttpURLConnection.plainConnect(Unknown Source)
at java.base/sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(Unknown Source)
at java.base/sun.net.www.protocol.http.HttpURLConnection.getOutputStream0(Unknown Source)
at java.base/sun.net.www.protocol.http.HttpURLConnection.getOutputStream(Unknown Source)
at java.base/sun.net.www.protocol.https.HttpsURLConnectionImpl.getOutputStream(Unknown Source)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:410)
... 15 more
Ignition v8.1.21 (b2022092908)
Java: Azul Systems, Inc. 11.0.15
It also affects the tag browser, by just showing Error on all the tags. What is this issue and is there a way to correct it? I'm assuming it due to an ethernet communication issue, but I don't know why since the edge gateway is running on the same hardware as the plc.
