When I have a power table, and I have “Wrap Text?” set on a column in the Table Customizer, and at least one cell in that column is wrapped, and I set horizontalAlignment or verticalAlignment in the configureCell extension function, I get an exception and in fact it makes the Designer slow to a crawl. I know, that’s a lot of “ands.” My only workaround here is to disable “Wrap Text?” and manually wrap the text myself in configureCell by prepending an html tag and replacing some of the spaces with line break tags.
I searched through the forum and didn’t find this previously reported.
Full exception here:
Exception in thread “AWT-EventQueue-2” com.google.common.util.concurrent.UncheckedExecutionException: java.lang.IllegalArgumentException: No such property: horizontalAlignment
at com.google.common.cache.LocalCache$Segment.get(LocalCache.java:2203)
at com.google.common.cache.LocalCache.get(LocalCache.java:3937)
at com.google.common.cache.LocalCache.getOrLoad(LocalCache.java:3941)
at com.google.common.cache.LocalCache$LocalLoadingCache.get(LocalCache.java:4824)
at com.inductiveautomation.ignition.common.util.BeanHelper.set(BeanHelper.java:196)
at com.inductiveautomation.ignition.common.util.BeanHelper.setQuiet(BeanHelper.java:216)
at com.inductiveautomation.factorypmi.application.components.VisionAdvancedTable$Renderer.getTableCellRendererComponent(VisionAdvancedTable.java:1539)
at com.jidesoft.grid.JideTable.prepareRenderer(Unknown Source)
at com.jidesoft.grid.CellStyleTable.prepareRenderer(Unknown Source)
at com.jidesoft.plaf.basic.BasicJideTableUIDelegate.paintCell(Unknown Source)
at com.jidesoft.plaf.basic.BasicJideTableUIDelegate.a(Unknown Source)
at com.jidesoft.plaf.basic.BasicJideTableUIDelegate.paint(Unknown Source)
at com.jidesoft.plaf.basic.BasicCellSpanTableUIDelegate.paint(Unknown Source)
at com.jidesoft.plaf.basic.BasicCellSpanTableUI.paint(Unknown Source)
at javax.swing.plaf.ComponentUI.update(Unknown Source)
at javax.swing.JComponent.paintComponent(Unknown Source)
at com.jidesoft.grid.CellStyleTable.paintComponent(Unknown Source)
at com.inductiveautomation.factorypmi.application.components.VisionAdvancedTable$4.paintComponent(VisionAdvancedTable.java:256)
at javax.swing.JComponent.paint(Unknown Source)
at javax.swing.JComponent.paintChildren(Unknown Source)
at javax.swing.JViewport.paint(Unknown Source)
at com.inductiveautomation.vision.api.client.components.model.AbstractVisionPanel.paintChildren(AbstractVisionPanel.java:272)
at javax.swing.JLayeredPane.paint(Unknown Source)
at com.inductiveautomation.ignition.designer.designable.DesignPanel$DesignableContainerLayer.paintChildren(DesignPanel.java:1183)
at javax.swing.JComponent.paintToOffscreen(Unknown Source)
at javax.swing.RepaintManager$PaintManager.paintDoubleBuffered(Unknown Source)
at javax.swing.RepaintManager$PaintManager.paint(Unknown Source)
at javax.swing.RepaintManager.paint(Unknown Source)
at javax.swing.JComponent._paintImmediately(Unknown Source)
at javax.swing.JComponent.paintImmediately(Unknown Source)
at javax.swing.RepaintManager$4.run(Unknown Source)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
at javax.swing.RepaintManager.paintDirtyRegions(Unknown Source)
at javax.swing.RepaintManager.prePaintDirtyRegions(Unknown Source)
at javax.swing.RepaintManager.access$1200(Unknown Source)
at javax.swing.RepaintManager$ProcessingRunnable.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.access$500(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
Caused by: java.lang.IllegalArgumentException: No such property: horizontalAlignment
at com.inductiveautomation.ignition.common.util.BeanHelper$2.load(BeanHelper.java:58)
at com.inductiveautomation.ignition.common.util.BeanHelper$2.load(BeanHelper.java:50)
at com.google.common.cache.LocalCache$LoadingValueReference.loadFuture(LocalCache.java:3527)
at com.google.common.cache.LocalCache$Segment.loadSync(LocalCache.java:2319)
at com.google.common.cache.LocalCache$Segment.lockedGetOrLoad(LocalCache.java:2282)
at com.google.common.cache.LocalCache$Segment.get(LocalCache.java:2197)
… 76 more
