I tried to use the Layout for an image control to anchor it center of the window and to the south. It looks like it is anchoring the top of the image south, which causes the image to be outside the viewable area inside the designer. When I change to runtime it looks like it anchors in the center vertically and horizontally.
Ignition 7.0.3
I’m not seeing this behavior. It is all working as expected for me. Perhaps you could post a screenshot of the offending component? Are you sure you don’t have it docked north and south? that would cause it to stretch in odd ways.
Well, now it is not doing it, but I have also rebooted my PC since I posted that. Maybe it was just an odd occurrence.
Darren
Ok, let us know if you’re able to reproduce it.
