Hi
I have add a SVG trough the Image management.
Now I want to add the image to a button, but I can't find the image.
I have also tried to take the path but this I can't get to work either.
What are I'm missing?
Try using the source property instead,
image.source : /system/images/Builtin/icons/resume.svg
I would encourage you to think about your image folder structure. Keep your own icons separate from the built-in ones and create folders for images to be shared across all applications (company logos, etc.) and images for specific applications.
Thanks. it work.
Good. Don't forget to mark my post as "Solution". It helps others with a similar question.
