Hi, i Want to incruse a image in a cell of data of a power table, is it possible ? I have my database in Mysql and I want to based in this sentence and in the component based example such as configure cell but not colors, images of my repository. if someone can helpme please with this.
SELECT
CASE
WHEN EXISTS (
SELECT 1
FROM mantenimiento.INSTRUCTIVOS_COMPONENTE
WHERE EQUIPO_ID_EQUIPO = '155'
) THEN 1
ELSE 0
END AS resultado;
Do you want the image in a Power Chart (graph) or a Power Table (table)?
If it is in a Power Table, the ConfigureCell extension function with the IconPath property is likely your best bet
Your question title says Power Chart. The body of the post says "power table". Which is it?
It looks like a Vision question so include the vision tag from the dropdown below your question title.
Please also see Wiki - how to post code on this forum.
Formatted query
SELECT
CASE
WHEN EXISTS (
SELECT 1
) THEN 1
ELSE 0
END
AS resultado;
I want the image in a power table, I tried in the configure cell but don't works, is there any other form?
Where are your images stored? If they are stored in Ignition's image manager, the IconPath property in the return dictionary should work
In my image browser for example this is the image componentesFV.png.
Could you help me with one example how to do this with configure cell please?
if value == 1 :
return {"iconPath": "componentesFV.png", "text": ""}
else :
return {"text":""} # Don't show the 0
Is there any form to change the size of the image ? this is my code.
def configureCell(self, value, textValue, selected, rowIndex, colIndex, colName, rowView, colView):
if colName != "Numero":
return None
else:
Infraestructura=self.data.getValueAt(rowIndex,"CATEGORIA")
if Infraestructura == "INFRAESTRUCTURA NECESARIA" :
else :
return {"text":""}
Resizing the image in code is a lot more complicated. If you only have a fixed set of icons, it's going to be a lot easier to just manually make resized copies and upload those to image management separately.
