Image in Table Cell
Hi. Happy new year to all!
I have a Table and I need to show only pictures.
I could do this from Table Customizer(image path list), but I don’t know how many columns I will have.
Is it possible to make in my script?
How?
Exemple:
I am going to assume the images you want to display are in the ImageManager on your gateway.
All you have to do is the following:
if colName == "MyImageColumn":
    return {"iconPath":value}
If the image is not in the ImageManager, it is a little more difficult. Let me know if this is what you are after.
It’s perfect for Power Table. Thanks!
But do you know how to make this in the Table?
You don’t. Use a power table. Is there a reason you would rather not use a power table?
I will use a poer table. Thank you very much for your help.
For those who want to use a regular table, you can work with the “Image path column” and “Image path list” to translate keys to images.
https://docs.inductiveautomation.com:8443/display/DOC79/Table+Customizer
