Hi all. I need to export the images/folders/structure from the Image Management section across to another gateway. Gateway backup/restore is out of the question as the gateway configs are totally different. I need to be able to export the project with its images. Is this possible?
You can export the project from within the designer or the gateway. If you do the export from the designer you will see a popup box that has options as to what you can export. The images in your image management tool can be exported separately, same with your SQL tags.
