Image Management - Perspective
I am having an issue with the latest update for ignition (8.1.0). I have objects that I had gathered from the image factory in perspective that were binded. However, I am unable to see my objects now. The objects were created to bind to color properties and change colors depending on the integer value of a particular “tag”.
We’re going to need some more information because it seems like you’re mixing terms. It sounds like you’re using svgs from the Symbol Factory (which is not the same as Image Management). Can you provide more info about which symbol you’re using, as well as a more detailed explanation of your setup? Could you provide a screenshot of the binding dialog and any transforms you have applied? What sort of container is the svg contained within? Is there any chance you could provide the view.json file for the View in question?
