V7.6.1, in tab strip component,
I don’t’ find some options to align text right, with image left for exemple or to configure space between text and image ?
perhaps html code for the DISPLAY_NAME ? ![]()
Click on the Edit Tab Icon in the tab strip customizer. Choose your horizontal and vertical alignment from the popup menu. Then, press okay. To configure space between image and text, simply put spaces at the end or beginnning of the display name field.
Yes, I use these options, but I try to align all the image icon on the left side ?
Change the orientation of the tab strip to the left or right depending on your preference. Also, choose align left for “horizontal alignment” when you click on the Edit Tab Icon.
