Good morning, is there a way to render an image inside a perspective Table?
Yes, place the url for the image in a column's data, set that column to render via a nested view, and supply a view that accepts the image url as the value parameter, passing it to an image component.
You might find this topic helpful:
Automation Professionals is pleased to announce an alpha release of its new Blob Server Module.
Available only for Ignition v8.1, here.
The Blob Server Module provides a simple way to deliver images, PDF files, or other binary content from a database to your Perspective clients or other web applications. Without needing the WebDev module. All you need is a Named Query that has appropriate security settings and returns a single row with two columns: Content, and ContentType.
Modest documentati…
