Hello,
I have a question regarding Ignition Perspective.
I am trying to organize images by using a Coordinate Container inside another Coordinate Container, because Perspective does not have a “group” feature and this is the closest alternative.
However, I keep running into a very frustrating issue.
1. Problem Description
When I place an Image component inside an inner Coordinate container:
The image cannot be dragged in the Designer workspace.
Only rotation works.
I can move it by manually editing position.x and position.y,
but dragging with the mouse does not work at all. -
If I delete the inner Coordinate container, the exact same image
becomes fully draggable again.
root (Coordinate)
└ InnerCoordinate (Coordinate)
└ Image ← cannot drag
root
└ Image ← dragging works normally
This behavior is consistent and has been blocking my work for 3 days.
2. What I have already tried (none worked)
Reinstalled Ignition (even on C drive)
- Checked layer overlap issues
- Checked overflow settings
- Checked pointerEvents
- Checked z-order conflicts
- Checked project structure
- Checked if Designer was in a temporary bad state
- Verified “visible” flags
- Tried Close & Revert in case the View was corrupted
→ None of these solved the issue.
3. What I am trying to achieve
Before starting a larger collaborative project,
I want to establish a clean image-organization structure.
Since there is no “group” feature, I want to organize images like this:
root
└ GroupA (Coordinate)
└ Images
└ GroupB (Coordinate)
└ Images
└ GroupC (Coordinate)
└ Images
And I need to be able to drag images freely inside these Coordinate containers.
But currently, any Image inside any Coordinate container becomes non-draggable.
4. Additional issue in Project Browser
In the Project Browser,
I cannot reorder Image components by dragging them up/down.
In some cases, z-order does not update properly either.
I don’t know if this is related, but it is causing extra confusion.
5. Request for help
I’m a designer (non-developer), and I cannot figure out why this happens.
Is there a known cause for this issue?
Is there a correct or recommended way to nest Coordinate containers
and still be able to drag Image components normally?
Any guidance would be greatly appreciated.
Thank you.
