Hello,
Can the experts help me to solve the following mystery?.
I have a 3rd party lib, which I have installed in /var/lib/ignition/user-lib/pylib/ following the advices of the documentation. It is called dimc.py which uses a dimc.so also placed at the same area. The code of dimc.py is just:
def bootstrap():
global bootstrap, loader, file
import sys, pkg_resources, imp
file = pkg_resources.resource_filename(name,'dimc.so')
loader = None; del bootstrap, loader
imp.load_dynamic(name,file)
bootstrap()
BTW, I have not created it, I just deploy it because I want to use it for another things, and it has been used as it is by my community since years. So I use my python console in a linux machine and I just reproduce the code knowing exactly the placement of the lib:
$ python
Python 2.7.5 (default, Apr 2 2020, 13:16:51)
[GCC 4.8.5 20150623 (Red Hat 4.8.5-39)] on linux2
Type "help", "copyright", "credits" or "license" for more information.
import sys,imp
imp.load_dynamic("dimc","/var/lib/ignition/user-lib/pylib/dimc.so")
<module 'dimc' from '/var/lib/ignition/user-lib/pylib/dimc.so'>
I try the same from the script console in the designer:
Input Error: No module named dimc
What should I do to make this workable?.
Thanks in advance,
Patricia
