Implement jwt in Ignition 8.1
How can I implement jwt library or an equivalent in Ignition 8.1 ?
Have you tried dropping the java-jwt library into Ignition's install folder? (lib/core/common)
FWIW - Ignition uses jose4j which is distributed as a common dependency - should already be in lib/core/common. You could consider calling out to this library’s Java APIs for your JWT needs since it is already on the classpath.
OK I have a “jose4j-0.9.6.jar” file in my lib/core/common file.
I can’t use RSA but only HMAC. I can’t import RsaJsonWebKey or RsaKey
