Import and export tags
Hello everyone, I'm exporting a bunch of tags in order to make some modifications to each tag. After modifying the exported file, I import it back into my project. Everything in the tag browser seems good; all the modified tags also change in the tag browser. However, the problem is that all the tags spread over all screens in the application did not change. So my question is, is there a way to also change the tag names in all screens according to the new tags imported?
I'm importing in direct mode, collision Policy Overwrite
Your best bet is to probably just make a spreadsheet with old vs new tagPath; then go through the list and use Find/Replace on each. (I would personally only use find/replace with the full tag paths to make sure you don't accidentally overwrite anything you weren't intending to.)
