Is there a way to import tag providers from another gateway without doing a gateway restore?
Tags themselves are importable / exportable, but... before you do that, are you sure that's what you actually want? What are you trying to accomplish?
Thanks. I just found out how to do that. I'm looking to import tags to another gateway that have run the same projects.
Okay, exporting/importing tags may be what you're looking for.
The same "projects" isn't necessarily enough though. DB tags need will need the same DB connections. OPC tags will need the same OPC servers and devices.
Good point. Thanks. I did add all those as well.
