Import excel data into table
i want to import my excel file into perspective ignition.
i am using this script:
def excelToDataSet(fileName, hasHeaders = False, sheetNum = 0, firstRow = None, lastRow = None, firstCol = None, lastCol = None):
	import org.apache.poi.ss.usermodel.WorkbookFactory as WorkbookFactory
	import org.apache.poi.ss.usermodel.DateUtil as DateUtil
	from java.io import FileInputStream
	from java.util import Date
	   Function to create a dataset from an Excel spreadsheet. It will try to automatically detect the boundaries of the data,
	   but helper parameters are available:
	   params:
	   		fileName   - The path to the Excel spreadsheet. (required)
	   		hasHeaders - If true, uses the first row of the spreadsheet as column names.
	   		sheetNum   - select the sheet to process. defaults to the first sheet.
	   		firstRow   - select first row to process.
	   		lastRow    - select last row to process.
	   		firstCol   - select first column to process
	   		lastCol    - select last column toprocess
	fileStream = FileInputStream(fileName)
	wb = WorkbookFactory.create(fileStream)
	sheet = wb.getSheetAt(sheetNum)
	if firstRow is None:
		firstRow = sheet.getFirstRowNum()
	if lastRow is None:
		lastRow = sheet.getLastRowNum()
	data = []
	for i in range(firstRow , lastRow + 1):
		row = sheet.getRow(i)
		print str(i).zfill(3), list(row)
		if i == firstRow:
			if firstCol is None:
				firstCol = row.getFirstCellNum()
			if lastCol is None:
				lastCol  = row.getLastCellNum()
			else:
				# if lastCol is specified add 1 to it.
				lastCol += 1
			if hasHeaders:
				headers = list(row)[firstCol:lastCol]
			else:
				headers = ['Col'+str(i) for i in range(firstCol, lastCol)]
		rowOut = []
		for j in range(firstCol, lastCol):
			if i == firstRow and hasHeaders:
				pass
			else:
				cell = row.getCell(j)
				cellType = cell.getCellType().toString()
				if cellType == 'NUMERIC':
					if DateUtil.isCellDateFormatted(cell):
						value =  cell.dateCellValue
					else:
						value = cell.getNumericCellValue()
						if value == int(value):
							value = int(value)
				elif cellType == 'STRING':
					value = cell.getStringCellValue()
				elif cellType == 'BOOLEAN':
					value = cell.getBooleanCellValue()
				elif cellType == 'BLANK':
					value = None
				elif cellType == 'FORMULA':
					formulatype=str(cell.getCachedFormulaResultType())
					if formulatype == 'NUMERIC':
						else:
								value = int(value)
					elif formulatype == 'STRING':
					elif formulatype == 'BOOLEAN':
					elif formulatype == 'BLANK':
						value = None
				else:
					value = None
				rowOut.append(value)
		if len(rowOut) > 0:
			data.append(rowOut)
	fileStream.close()
	return system.dataset.toDataSet(headers, data)
# Read .xlsx file
fName = '<U+202A><U+202A>D:/SaleData.xlsx'
ds1 = excelToDataSet(fName, True)
util.printDataSet(ds1)
self.getSibling("Table").props.data = ds1
but i got an error:
File "function:runAction", line 96, in runAction
File "function:runAction", line 21, in excelToDataSet
java.io.FileNotFoundException: java.io.FileNotFoundException: ‪‪D:\SaleData.xlsx (The filename, directory name, or volume label syntax is incorrect)
please guide me
You marked this as Perspective. Perspective cannot directly access files on the client machine. You must use a File Upload Component.
Look closer in the thread you took the code from, it discusses ByteArrayInputStream
