Import export client/gateway event scripts
I know we can do this within Script Modules, but can we do this for Event Scripts?
Unfortunately, no you cannot import/export event scripts. You would have to copy/paste right now.
Is this still the case? Any possibility of getting some import/export functionality developed?
I don’t think anything has changed in the UI, but in 8.x they are all split apart on the filesystem now, which is at least a little better.
edit: err, script modules are, gateway events are still in a blob resource.
Thanks Kevin,
Damn I’m interested in Gateway and Client event scripts at the moment (tag change, timer).
That’s fine, its just a bit of a copy/paste exercise. Shouldn’t take that long.
I just try to avoid such tasks if i can help it!
Cheers
We’re hoping to split these into true separate resources (also human-readable on disk) and improve the UI in 8.2.
I’ve been copying and pasting for so long I don’t know if I can do it another way. :wink:
Is this slated to be in 8.3 now?
I guess you are on a version newer than 8.1.41? Is this 8.3 or just later 8.1? My 8.1.41 does not have this. Either way looks good!
Yeah, that's from 8.3.
