Import Google Font into project using CSS
I’m trying to import google fonts into my project but it’s not quite working the way I would expect. I have an index.css file that points to a number of other files and I’ve tested it and the index file works. In the index file, I am pointing to the fonts.css file and as far as I can tell, that all checks out the way it should. I don’t think the issue is a pathing issue.
The fonts.css file has this path:
C:\Program Files\Inductive Automation\Ignition\data\modules\com.inductiveautomation.perspective\themes\myThemes\fonts
The fonts.css file has the following code:
@font-face {
    font-family: "Kirang Haerang";
    src: url('https://fonts.googleapis.com/css2?family=Kirang+Haerang&display=swap');
Then in the project, I put Kirang Haerang for fontFamily, but noting changes.
I’ve also tried downloading the actual font and having the src point to that instead, but it also doesn’t work.
What am I doing wrong.
Thanks. I moved the font to the font folder and it worked.
np,
mark this topic as solved please.
Hello Guys:
I had this same problem, but it didn't work for me
I followed the steps below
  • I put a folder with ".tff" files in the /data/modules/com.inductiveautomation.perspective/fonts directory
  • I include the new font in the "font.css"
Another step I've done is to include the sources in the window, but with no results.
When I started the project the text object continues with another font.
also
inspecting the browser to see the loaded css file might give some clues
