Import Java Class to the designer Ignition
Hi! everybody
i have a problem , wrote jar and need using in designer for ejecute in button by script, i have compile it and run de pack200 to generare of jar.pack.gz . place file in core/lib/commom also core/lib/designer but no work.
i try witch follow code
def Asterisk():
from ignitionphone (this is mi package) import HelloManager (this is my class)
originate = HelloManager().run
call = Asterisk()
send this error
raceback (most recent call last):
File “”, line 5, in
File “”, line 2, in Asterisk
ImportError: No module named ignitionphone
Can you upload your JAR file somewhere for us to look at?
Hi Kevin, thanks for you asnwer
https://drive.google.com/open?id=1mpEwzzd9FfBdL1tmlNwgCXziHvvMkcEv
This place both files on file!
regards!!
Not only do you have additional jar files inside your jar file, which is not going to do what you’re hoping, you’ve placed your classes in a package called ignition.phone.ignitionphone rather than just ignitionphone like you’re referencing in the script.
Hi Kevin! as they say here SOS UN CRAK :smiley: , finally i see the class in designer, i now understand so so how work.
in my .jar missing a class java.util , i change de code python for this
def Asterisk():
from ignition.phone.ignitionphone import HelloManager
call = Asterisk()
as send
line 2, in Asterisk
java.lang.NoClassDefFoundError: org/asteriskjava/manager/action/ManagerAction
Thanks Bro!!!
